Home Forum Ask A Member Head torque and sequence.
  • #180724
    Tinman
      I have mainly 5.5- 30 hp omc motors from the 50’s. Is there a chart that shows the sequence and inch pounds of torque required for the different horse powers? Thanks!
      #180738
      bobw
        These should be what you need.
        Torque-Chart-OMC-
        Head-Bolt-Torque-Sequence
        • This reply was modified 5 years, 5 months ago by Mumbles.
        #180741
          Here ya go. When torquing the cylinder head, start in the middle and work your way out in a circle so the head gets tightened down evenly. I usually start with 50% of the given value the first time around and increase it to 75% the second time and 100% the third time around. Tightening it down in stages will help prevent warping the head.
          Note: This chart shows 5-7 and 8-10 Ft Lbs for the smaller motors. A torque wrench calibrated in inch pounds should be used for these motors as it will give greater accuracy. So that would be 60-84 and 96-120 Inch Lbs.
          Torque-Chart
          #180751
          Tinman
            Thank you bobw and mumbles, answered my question perfectly! Always appreciate the help!
            #180848
            Tinman
              When reusing head bolts should I go with the lower value in inch pounds? Thanks.
              #180871
                I just torque them to the middle somewhere of the given values and it seems to work fine. As long as the threads are clean and lubricated, torquing to the lower end will give similar clamping results if the threads are dry and torqued to the higher end of the given values.
                #180876
                Tinman
                  Thanks once again!
