Home › Forum › Ask A Member › Help!
  • #280944
    BenKruse
      All,
      I recently reworked a Handitwin’s electrical system with the pictured coil. What’s a new (available with part number) condenser that would work with this setup? The condenser I have used (to date, been through three) keeps strong spark for a short while then, it’s gone… Any help here is great.
      Ben
      #292347
      T….in Wisconsin
        JOSEPH BRINCAT
          Ben, are you saying that the condensers are failing? What condensers are you using? Have you actually tested them after removing them ?
          #292355
            These are 2 condensers I use. The top one has a value of .26 and the other is .22. These are automotive, point ignition, condensers. What were you using?
