Home › Forum › Ask A Member › Help getting my 67 Evinrude 3hp started
- This topic has 84 replies, 12 voices, and was last updated 6 years ago by
reivertom.
February 23, 2020 at 9:53 pm #195766
Take some time to watch Cajun’s series of videos explaining these ignition systems. He’ll walk you right thru it from start to finish. He also has some vids on carbs which might be worth checking out.
February 24, 2020 at 8:40 am #195780Part number for the fuel filter is 379635 or 594034. Several on eBay right now.
February 24, 2020 at 4:00 pm #195806February 25, 2020 at 9:33 am #195843Oops -those are Johnson numbers. Don’t know if they are the same as Evinrude. I would suspect they are interchangeable.
February 25, 2020 at 5:22 pm #195867Johnson and Evinrude part numbers are the same, If the part is the same
February 26, 2020 at 4:42 am #195886OK so I a at the point where I know the carb needs attention Sure enough when I took the bowl off I found that the inlet was blocked. That’s fied but now I’m doing the rest of the carby.
I’m using this as a guide.
https://outboard-boat-motor-repair.com/Evinrude%203%20HP%20Lightwin%20Outboard%20Boat%20Motor/Evinrude%20Johnson%203%20HP%201952-1967%20Carburetor%20Tune-UP.htmBut not finding the high speed nozzle easy to remove and not wanting to damage it wondering if I should leave it. Any tricks to getting it out or alternatively cleaning it in situ?
This reply was modified 6 years ago by
Elecmuso.
February 26, 2020 at 8:39 am #195895clean it with carb cleaner and blow dry with air pressure …. if you don’t have a compressor buy a can of keyboard air cleaner at the Dollar store.
if… I say if …..you have a very thin stiff wire smaller than the diameter of the jet and the hole is plugged just clean out the passage with the wire to poke out the crud if any
you should see light from the crab bowl when looking into it
at this stage I would not recommend you try to unscrew it without the proper tool
February 26, 2020 at 11:31 am #195903Are you trying to remove the fixed high speed jet, or the carb nozzle that is threaded into the center of the upper carburetor body? Like others have said, trying to remove the fixed high speed jet without the proper jet screwdriver usually results in damage to the jet and the threads….So, it may be best to soak the carb bowl in strong carb cleaner. Sometimes you can pass a small pipe cleaner through the fixed jet to help clean it also…
The main body nozzle simply threads into the body…Using a large screwdriver should easily remove it….If the nozzle is stuck also, I wouldn’t risk damaging it by forcing it out with the screwdriver. I would soak the upper body in strong carb cleaner as well…February 26, 2020 at 11:32 am #195904Have you cleaned out the fuel line, valve, adapter, and tank filter yet???
February 26, 2020 at 4:19 pm #195920Fleetwin
Yes I have a new fuel line, have thoroughly cleaned the valve / tap that screws into the tank (which was full of crud) and have ordered new inline fuel filter.
I’m not satisfied that my tank cleaning was adequate. I think I will use ‘nuts and bolts’ as per this video. Is that a reasonable way to provide the abrasion necessary to remove all the crud? -
