Home Forum Ask A Member Help please to identify prop ….Part number 310208
  • #221199
    Monte NZ
      International Member
      The above prop came with the 1964 Johnson JH 19A that I am currently working on.( See recent post re stripped thread in cylinder block)
      The parts list for the motor shows a 2 blade prop, whereas this prop has 3 blades (8X41/2 inches)
      Is this an alternative for the 3hp or is it for another model and secondly, the prop hub doesn’t appear to be able to be taken apart as the two bladed one is?
      Thanks again in advance.
      Monte NZ
      #221202
        A 310208 3-blade 8 x 4-1/2 is correct for JH models. A two-blade is for JW (weedless) models. Are you looking at the correct parts list? See page two on following link for prop chart.
        https://www.aomci.org/forums/topic/1960s-18-hp-evinrude/page/2/
        • This reply was modified 4 years, 5 months ago by frankr.
        #221226
        cajuncook1
          Monte NZ
          Here is the parts list for the 1964 Johnson 3hp JH gearcase.
          http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1964&hp=3&model=JH-19&manufacturer=Johnson&section=Gearcase+Group+Standard+Drive
          Cheers,
          Cajun
          #221282
          Monte NZ
            Thanks frankr and Cajun for your help once again………I hadn’t noticed that it was the alternative prop.
            Monte NZ
