I have angler issues
Home Forum Ask A Member I have angler issues
  • frankr
    Topics: 51
    #31584
    Here is what the beast looks likeL
    pic host
    how to take a screenshot on a pc
    wedgie
    Topics: 78
    #31586
    Wow Frank, Thanks for going to all the trouble !
    Thanks Ed. If your prop will fit I’d be interested. 😉
    If I can’t find a usable prop I guess I will keep this motor for parts for a 6 horse.
    melugin
    Topics: 32
    #31600
    I have a NOS Michigan wheel PJ-7, 8 x 7 1/2, 3 blade aluminum prop, last one here. This is the economy model which does not have the clutch hub, as the AMC Michigan prop. Send me a PM if you are interested. Shipping may cost more than the part, though.
    bbstacker1
    Topics: 4
    #31616
    Just happens to be one listed on ebay right now, not very often they come up.
    http://www.ebay.com/itm/201517647241?_t … EBIDX%3AIT
    enrico-italy
    Topics: 6
    #31618
    The thermostat was optional in Anglers.
    The cylinder head is exaclty the same of 6 hp, so it is easy to put it in place.
    The correct prop is a 8" x 7.5" x 3 blades, left handle, and is essentially similar to the 3 hp one, with the same shear pin and rubber ogive.
    I wondered the 5 hp can use a longer pitch than the 6 hp with the same gear ratio ( the 1976 and later 6hp uses 12:25 ratio and 8×7 prop instead of 15:26 and 8×71/4 of first series) but it is…
    I have a ’66 johnson LD 11 and I will check if a part number is on its prop.
    enrico-italy
    Topics: 6
    #31619
    oops… too late… I’m sorry…
    wedgie
    Topics: 78
    #31634
    You guys are awesome.
    I suppose I should get this Angler running first before I spend anything on it. I have a whole pile of 30 other motors to go through too and see which ones are viable to get running or just part them out. Up until now I had never considered trying to recoup my investment in this hobby.Now I have to due to space limitations with the doubling of the inventory overnight.
    Thanks again everyone for all the info 😀
    wedgie
    Topics: 78
    #32300
    I found a prop in my attic that I’d forgotten I had. Thanks for all the prop offers and indeed, I may need another one at some point for another motor.
    Popped in some fresh coils, cleaned the points, didn’t even touch the carb and it started on the 3rd pull.
    http://vid635.photobucket.com/albums/uu … d6lucs.mp4
    melugin
    Topics: 32
    #32316
    Dandy!
