Home Forum Ask A Member Identify an old prop and 2cyl crankshaft
Viewing 10 posts - 1 through 10 (of 21 total)
  • #243406
    Beno
      Im in the box of boat parts again!
      Not.indentifying marks on either of these pieces. A prop and a crankshaft… anyone know?
      IMG_20210721_153240_DRO
      #243416
      Beno
        IMG_20210721_153711_DRO
        IMG_20210721_153751_DRO
        IMG_20210721_153801_DRO
        #243421
        Beno
          IMG_20210721_153711_DRO-1
          IMG_20210721_153751_DRO-1
          IMG_20210721_153801_DRO-1
          #243428
          JOHN HOLBIK
            The prop looks like from a OMC 10 or 15hp.What is the pitch and diameter.
            #243434
              I’m thinking the prop might be from a 3 hp OMC and I’m pretty sure the crank is from a 15 hp, 18 hp or 22 cubic inch 25 hp OMC. I wish I could be more specific than that; but that’s all I got…..
              #243437
                I immediately said JW-10 prop, but that ain’t right. Hub is wrong. Now I’m thinking a McCulloch/Sears.
                Agreed, the crank probably is a 22 cu/in OMC.
                #243438
                  7.5hp McCulloch prop
                  7.5-mcculloch
                  #243443
                  outbdnut2
                    What is the inside diameter of the hole in the hub for the prop shaft? I’m thinkin’ early to mid 1950s small OMC – maybe 7-1/2 HP?
                    outboardnut
                      Frank your amazing!
                      #243448
                      modhydro
                        US Member - 2 Years
                        The crank sure looks like what I use in the 22ci pre 1976 omc engines. Is it for sale? Thanks
                        Steve
