Home Forum Ask A Member ignition coil gap
  • #179470
    wrenchero
      US Member - 2 Years
      hello all, i have several johnsons and evinrudes from the 50’s and 60’s.are there special tools to adjust the ignition coil gap or is there a shortcut.thanks
      mn
      #179472
      RICHARD A. WHITE
        If you are referring to the air gap between the coil heels and the magnets on the flywheel… Yes there is a reproduction tool. Click the link below.
        Check out http://www.richardsoutboardtools.com
        classicomctools@gmail.com
        #179498
        wrenchero
          US Member - 2 Years
          thank you i just emailed him.is it very important to get the timing tool also
          mn
          #179517
          wbeaton
            Canada Member - 2 Years
            Definitely buy both tools. Neither one is really necessary, but they make the job so much easier and give perfect results every time. I wouldn’t set the ignition on an OMC without them.
            Wayne
            Upper Canada Chapter
            uccaomci.com
            #180302
            crosbyman
              timing tool is great and precise .. I purchased one.
              precision is also obtainable manually using the VOM or test bulb ( a simple battery and bulb in series ) test procedure
              so it all depends on how frequent you need it
              http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
