Home Forum Ask A Member Ignition module to replace points & condenser in a magneto
  • #260747
      Been experimenting with later coils and ignition modules.
      Mostly curiosity as to updating to an electronic ignition
      not needing points or condenser. I had a strong start but
      the initial coil was not commonly used. This could turn
      into an availability issue. Won’t work if you cant get them.
      There is any number of coils out there. One big problem is
      the location of the wires. Ones that I did get to fit didn’t
      work or what was pictured isn’t what was sent.
      I have also purchased a 2 modules. I have seen a video
      where they were used replacing the points and condenser
      but he only showed the plugs firing. Not the motor running.
      So I tried both of the ones I have in Pal with the same,
      interesting???, result at the end of this video.
      https://youtu.be/t0jkx4INjYQ
      #260750
      dave-bernard
        I have 2 red atom modules for magneto.
        #260752
          Interesting! It’s hard to judge from the video, but would the motor start
          pulling the motor over with a rope using normal effort?
          With the .070 gap, I didn’t see spark for a while at low speeds,
          but think it was better with the .025 gap.
          How was this ignition module sensing when to fire, and why is
          it firing so much earlier than on the points and condenser set-up?
          labrador-guy
            Tubs I sure hope you can tell us how those module things work.   I replaced one on my neighbors John Deer.  It was mounted on the side of the engine case.   The mower had no spark, I ordered one just for kicks and it fired and ran great.  How does it know when to fire?   Newer Briggs n Stratton motors also have the one component spark making system.   It either works or it don’t!   No way to test the darn things.  How do they work?
            dale
            #260778
              First I’ll tell you what I do know. These little
              magneto will put out a spark just by giving
              them a good twist with your hand with the
              spark plug out. With the module its not even
              close.
              Will it start pulling over with a rope? Not
              sure as I didn’t try to. When I get the mag
              turned around and try it again that will be one
              thing I will try.
              How does it work? I don’t understand how any
              of this crap works. I believe the module senses
              when the polarity of the magnet changes as
              it passes over the coil and then produces the spark.
              How that is possible is beyond me and I may
              be totally wrong here and that’s not how it works
              at all.
              Here is something I’m curious about. If you
              put them in a 2 cylinder. Like the OMC universal
              mag that has points for each cylinder would you
              need to switch the plug wires?
              More experiments to come. I’ll be posting the
              results.
              • This reply was modified 2 years, 10 months ago by Tubs.
              #260808
                You need one module for each cylinder, or set of points.
                #261590
                labrador-guy
                  TBH I found this little tutorial on utube.  It makes the spark making process understandable.  I know from personal experience that the trigger coil starts the process.   When CDI started the only timing adjustment was at the trigger coil.   When the motor started it ran at full advance.  Nowadays most small engines run at full advance all the time.  Could one of these coils be adaptable to run on our old outboards?
                  This spring my lawn mowing equipment has used two coils so far.   They either work or they don’t.  None of my pack of mowers are new and none have ignition points or condensers.  I am purchasing some spare coils.  It would be nice to bolt on a coil on and old outboard that will spark and run without points and condensers.
                  https://www.youtube.com/watch?v=NNlYbvDY6pI
                  dale
                  #261611
                  rudderless
                    search debe atom as there is a lot of information.  He deconstructed an Atom eliminator and has the schematic to build one yourself.
