Home Forum Ask A Member Impeller Mercury KG7, Chris Craft, Oliver
  • #235562
      Good to know, Thanks!
      opposedtwin
        Good work Wayne! That’s why these motors will never be silent! We have guys in this club who can think through an obstacle and come up with a viable solution to keep them running! Thanks for sharing!
        #235625
        fastjohn
          For a KG-7, a Sierra 18-3051 or OMC 395289 will fit if you reduce the height (thickness). There was an article years ago in the Antique Outboarder explaining how to do it.
          #235772
          kirkp
            Good job Wayne. How did you arrive at the fact that Honda impeller at least had the correct OD and thickness? What would really be nice is some kind of database or whatever that gave dimensions for various impellers. Sierra has a lot of impellers available but they don’t list dimensions unless I’m missing it. I know, I’m asking a lot. LOL
            Kirk
            #235781
            wbeaton
              Thanks, Kirk. I knew that the Honda impeller is a suitable replacement for the Scott-Atwater impeller. Since the Scott-Atwater impeller fit in the housing I was confident the Honda would, as well. Which it did with a little work. However, if you Google different impellers you will find many aftermarket sellers list the impeller dimensions. Honda also makes a similar impeller with a 5/8” hub that might fit the KG7. I don’t have a KG7 so I didn’t order one to find out.
              Wayne
              Upper Canada Chapter
              uccaomci.com
