Home › Forum › Ask A Member › Impeller seal
- This topic has 7 replies, 3 voices, and was last updated 7 years, 1 month ago by
Samuel Phelps.
August 23, 2019 at 8:47 pm #181861
Anyone know a source for an impeller water seal ? Part # 200834 for the 49 Speeditwin
August 23, 2019 at 11:04 pm #181867I thought they used a Chicago Rawhide seal. Where there any numbers on it? That is supposed to be a 0.988″ shaft. Look for a seal at a wholesale house with an inside diameter of 25mm. Good Luck
Garry in Michigan
August 24, 2019 at 1:57 pm #181896August 24, 2019 at 2:14 pm #181899They did some strange things back then, but I doubt it is a metric part.
August 24, 2019 at 2:20 pm #181900Any chance you could substitute a quad ring? Hard to tell the size with a tape measure, but I’m thinking a 90025K381 from McMaster.
https://www.mcmaster.com/x-ringsAugust 24, 2019 at 6:44 pm #181916The ring fits on the shaft coupler resting on the impeller and seals in the beveled upper housing . So it’s either spinning with the shaft or it’s sticking to upper housing and shaft spinning inside the ring .. So thinking an o ring more this style idk ..https://www.mcmaster.com/o-rings
Basically just needs to be beveled on the outside I guess . Shaft mounted rotary seal 9562K47-
This reply was modified 7 years, 1 month ago by
Samuel Phelps.
Samuel Phelps.
August 25, 2019 at 1:19 pm #181960Sorry – I was looking at the wrong part. The water intake on those models was larger than the water tube. At speed more water was forced in than the output could handle. The water would fill the driveshaft housing and rust the crank shaft.That seal was the first attempt to stop that. some were cork. some were leather. Later holes were drilled to let the water out of the housing, which solved the problem. It was common for racers to remove that seal, shave down the water pump and drill extra holes in the driveshaft housing to gain a little more horse power. A small “O” ring will do – it’s not that important.
Garry in Michigan
garry-in-michigan.
August 25, 2019 at 8:44 pm #181975That’s interesting thanks for the info . Is that what that small hole in the housing on the second picture is for ?
