Home Forum Ask A Member In search of parts for a 1932 Johnson k-50
  • #288856
    MHarrington
      US Junior Member
      Hi, I am in search of a coil, lower unit, and maybe a flywheel for my 1932 Johnson k-50.  If anyone knows how to fix my coil the problem is where the spark plug wire connects- the connecting piece has broken off but left all of the plastic or whatever it is that resembles plastic behind.  I am open to ideas, but it will most likely end up needing replaced.
      #288897
      The Boat House
        I’ve lost access to my pictures so I’m not sure what coil you have. You shouldn’t try to use that coil. It’s possible to adapt a later coil to many of the early magnetos. Here is a link to Doug and Matt Penn’s sight. They should be able to help you with parts but they probably won’t get back to you till after the holiday. Tubs
        https://www.oldoutboard.com/
        #288909
        stanley
          US Member - 2 Years
          You can find compatible donors on these lists.
          #288921
          MHarrington
            US Junior Member
            Thank you for the help, I have one last question.  Does anyone know where I can get decals for this outboard, I have been unable to find one nor can I take measurements or pictures of the one that would have been on this one outboard because it is completely gone.
