Home › Forum › Ask A Member › Initial Setting for Flambeau needle valves
I’m working on a Flambeau Twin. Can anyone tell me the initial settings for the two geared needle valves? Should I adjust them with the motor running, then install the gear in the middle?
Any help is appreciated. Thanks!
Tom
Tom, do you have the Flambeau instructions PDF? If not, I can sent it to you via WeTransfer if you pm me your email address.
Got it, thanks!
T
Buccaneer wrote: Tom, do you have the Flambeau instructions PDF? If not, I can sent it to you via WeTransfer if you pm me your email address.
Buc; I would like to have the Flambeau manual. Just picked up a Flambeau last week.
Thanks!
Chuck, pm me your email address.
