Home Forum Ask A Member Installing points cam..’76 Johnson 15 hp
  • #1275
    RICHARD A. WHITE
      Installing points cam..’76 Johnson 15 hp. I am under the impression it should just slide on???? That ain’t happening. I even removed the flywheel key, still wont go…I am VERY confident that if I try to force this down it WILL split…This should have like .002 clearance or something…Right???? Thoughts?
      Oh and one more thing…..The old one was a mother. ******** to get off…. I did get it off without breaking but when I used a socket to tap it down and back on it split… It IS the correct number… Heat it up and then install?
      Thanks
      Richard
      classicomctools@gmail.com
      #14381
      dan-in-tn
        Those cams are made from cindered metal so I don’t think you would want to heat them. Not sure what is causing the installation problem. I don’t think they would have a press fit at all. The way they are made the metal is quite fragile to impact. That is the way I understand it. The metal is long wearing.
        Dan in TN
