Home Forum Ask A Member Is there tilt and trim unit for my J25RESB 1990 Johnson 25 hp ???
  • #198334
    outboardnut
      The actuator on my CMC tilt and trim unit bought the farm.
      Instead getting another actuator I thought maybe OMC made a tilt and trim unit
      #198372
      johnyrude200
        no they did not. Is the CMC trim unit just the bracket that bolts to the transom, then you hang the motor off the trim unit?
        I would recommend switching to a Panther integrated trim unit. They made an actual trim unit that fits all the OMC 20-35hp motors with the through-tilt-tube steering style stern bracket, not the smaller older style fastwin style stern brackets. I have one installed on my 1984 35hp model and they look nifty, work fine, and IMHO are better than the CMC products.
        #198422
        outboardnut
          Thank You for the suggestion about the Panther. But a new Panther would cost $700. The replacement actuator for my CMC is $400.00. Plus – My CMC is already mounted on the boat.I was hoping that OMC made a tilt and trim for my engine that would cost less than $400.00
          CMC bolts to transom and then you hang motor on the trim unit.
          https://boatstore.com/550025-trim-tilt-elect-je.html
