Home › Forum › Ask A Member › Is this a 9.5 gearcase?
- This topic has 12 replies, 8 voices, and was last updated 11 years, 5 months ago by
chinewalker.
May 3, 2015 at 5:31 am #1393
Looks to fit a 6/9.5hp…what are the extra fins on the skeg for? It’s overall in pretty good shape.
May 3, 2015 at 8:04 am #15245I would guess it is an attempt to protect the prop from rocks, etc.
May 3, 2015 at 1:15 pm #15255Supposedly, it helps to get it up on plane. Trim tabs, if you will. I’m a bit surprised, I didn’t realize they were put on small motors like that. They did make a bunch of motors in the 40hp class with them. I lot of people would cut them off. They caused more drag than they benefitted. Not to mention how many weeds they gathered up here in the swamps.
May 3, 2015 at 1:25 pm #15257Sounds like a good candidate to add to my oddities and notables collection.
I acquired one of the prop guard accessories for a 6hp motor recently too (the kind that looks like a big round shield encapsulating the prop). Im sure this keeps the prop safe, but I wonder how much drag it created.
May 3, 2015 at 4:27 pm #15261The diameter of the lower driveshaft bushing might determine whether it is for a 6 or 9.5/9.9/15commercial.
May 3, 2015 at 8:36 pm #15273I have a brand new gearcase housing in that size with with the wings. The part number makes it a commercial 14hp. The years I show that was built were 1988 & ’89. Not sure if it was used anywhere else. It should fit other engines, but not sure which ones. I have had a tough time figuring out what parts go inside to make it a complete gearcase assembly. It has a bearing driveshaft both upper and lower. Seems to be a heavy duty case. I am like Frank and others. If I was to use it, the wings would be removed.
Dan in TN
May 4, 2015 at 1:38 pm #15315The Commercial 14 unit used the larger 5-bolt gear case housing, commonly used on the (then) 28 SPL. The unit in the pic above is a smaller 4-bolt housing, as used on the 6 & 9.5 series. That is the first time I’ve seen a winged skeg on one of those gear cases, but I have seen them on the 14/25 and 40hp gear cases.
May 4, 2015 at 2:01 pm #15316Must be a rare prototype that should be coveted by wealthy oil-barons who would pay high $$$ for my retirement fund (JOKING).
May 4, 2015 at 2:50 pm #15322I have a 1981 6hp Johnson "workhorse" (commerical?) engine that came with those wings on the lower.
May 4, 2015 at 2:56 pm #15323That may be what it is from…
