Home Forum Ask A Member Jetmaster 8hp outboard
  • #9320
    chancem007
      I found an old jetmaster outboard motor made by California jet marine and air research from Beverly Hills, CA. Anyone know any more about this motor? Rare? What is it worth? Etc. any information would be great.
        All I know is what I read in Peter Hunn’s "the Old Outboard Book" . . . 😎
        #71799
        mike-stroz
          I wouldn’t mind getting something like that. Looks pretty interesting
          #71816
          wbeaton
            It’s a Cal Jet from the 1960’s. This is a deluxe model. I think your decal must say 3.8 hp and not 8 hp as the Cal Jets used a 4 hp Lauson Power Products – Tecumseh air cooled power head. It’s a very neat motor. I have the Econo-Jet version. It pushes more like a 2 hp or less. It’s not especially rare or valuable. I paid $100 for mine and I get chastised about it all the time. Money well spent to me. It’s a goofy underperforming outboard with this crazy windup starter recoil – I love it.
            Also, here is some information I learned about mine that is INVALUABLE. Mine would overheat. Turns out I had the carb set to lean.
            Exclamation Re: Help identify Lauson outboard jetdrive?
            When you adjust your carb, do not set it so the engine sings like a bee at high speed! Proper setting is to adjust for best running, after the engine is warmed up, THEN back out the fuel adjuster until the engine JUST begins to break up. If you set up too lean, it causes overheating as described in the forum posted by Steve AW. At idle, set for best running, then back out the needle 1/8 turn. Steve, if you are on that forum, please pass along the info I posted. The owner probably has it set too lean. One other thing will cause heating – bad crankshaft seals.
            I am surprised that that engine has the wind up starter. Those starters were only used for a few years, due to the fact that the sudden application of the strong spring on the pawl and crankshaft often lead to 2 things. 1) the starter pawl would break out the side of the starter cup on the engine or 2) the starter would actually snap the crank, where it passed into the block! A better choice would have been the pull cord starter. They both use the same starter cup and mounting on the engine shroud. Nice looking units!
            Wayne
            Upper Canada Chapter
            uccaomci.com
            #71819
            kevinrude
              According to Mr. Hunn’s book, the Cal-Jet was produced for only one year (1965) and came in three models: 4-HP Econojet (E-4), Ramjet (R-4) and Jetmaster (8.8 HP). Some had crank release starters.
              I’ve got a Schnake Mid-Jet and a Cary Jet. I might have to think about getting into Jet Motor collecting. Hmmmmmm.
              Headquartered at 9747 Wiltshire Blvd. in Beverly Hills, CA. A quick look at this address in Google Maps shows what looks to be a 60s era office building. Could be the same place?!?
              #71826
                #71833
                labrador-guy
                  My flyer is a little different than Mister Tubs. 4400 might be a four horse power. Address is also different.
                  dale
                  kirkp
                    The advertising lit is a hoot. You listen to the marketing department it was the best thing since sliced bread. I like how they give stats (such as 11 knot speed) that the majority of people couldn’t compare to other motors.
                    #71865
                    wbeaton
                      That’s cool. I didn’t realize they made an 8.8 hp. The cylinder doesn’t seem any bigger than the 4 hp, but it’s hard to tell in a photo I guess. The Cal Jet was produced for more than one year. There are references to them in magazines as early as 1962.
                      Wayne
                      uccaomci.com
                      #250071
                      mike n
                        i looked at one 20 years ago in an old mans shed. i liked it and asked him how much. he told me he could get 600 on ebay. i didnt buy it but i thought it was a neat engine and would like to have one
                        mn
