Home › Forum › Ask A Member › Johnson 1957 18hp Flywheel Problems
Viewing 10 posts - 1 through 10 (of 34 total)
  • #1067
    rschiff
      Ok,
      …I have tried everything I have learned in my short 6 months of working on older motors and I can’t budge the flywheel on this motor. I have a flywheel puller and felt like it was about to explode earlier as I torqued it down. Hit it square with hammer, etc. Am I missing something? Is there anything else that needs to be done to get this puppy to move.
      #13081
        Are you using the OMC puller? Maybe try an impact gun on the main puller screw.
        #13082
        LLOYD LAUTNER
          Did you loosen the flywheel nut? Don’t mean to be sarcastic. It does happen.
          #13083
            Are you lifting or levering the flywheel upward while you whack the puller bolt? BTW, don’t beat heck out of it, a sharp whack is more effective. It’s the shock that does it, not the bash.
            #13084
            rschiff
              I am trying to lever it up with the back of a hammer pivoting on top of the powerhead but was scared to pry to hard as it is only on one side, but to answer your question, yes I tried prying and hitting with hammer. And I am only hitting it once at a time with max torque on flywheel, no beating on it. 🙂
              #13092
              jerry-ahrens
                For the really stubborn ones, I would recommend the OMC factory puller. The puller plate is very thick and doesn’t have any give when torqued down.
                #13093
                jim-moffatt
                  use a torch to heat up the hub and expand it. Make sure the rim where the magnets are doesnt get too hot to touch otherwise they wil loose their charge.
                  #13117
                  rschiff
                    Ok here are some pics just in case I am not seeing "clearly"…No judging me if I am missing something stupid! Wont be the first or the last time.
                    Scared to try the heating technique just yet.
                    #13119
                      You haven’t busted the bolts yet, so you must not be mean enough. Give it H…., it will come off. Nothing to do with pulling it, but do you have the ring that’s missing from the flywheel?
                      #13120
                      rschiff
                        Yes, I took it off trying to find anything I was missing. Heavy sucker.
