The motor (CD-19 S) starts and runs nicely, but something is off with the throttle linkage, or spark/carb sync, as the motor won’t run below the “start” position on the twist grip, regardless of carb settings. It almost acts as if the gears in the twist grip mechanism were out of time, but I don’t think that is the case, if even possible. I do notice that the arm at the top of the vertical shaft (that moves the stator plate via a link) taps the side of the hood when at the “stop” end of travel.
I have double-checked the timing using the timing marks on the flywheel. The throttle cam is adjusted all the way out. I do notice that the carb throttle shaft doesn’t begin to rotate until the index mark on the cam is about 3/16″ to the left of the centerline of the roller.
This doesn’t prevent using the motor, but bugs me. Suggestions? I’m missing something!
