Home › Forum › Ask A Member › Johnson 210 tower is twisted
  • #208673
    jim-moffatt
      After my last run the Tower of my Johnson 210 is twisted about 10 degrees. Any suggested fixes?
      The tower consists of upper and lower castings attached to an aluminum tube.
      #208709
        Did the tube twist, or the castings twisted on the tube?
        jim-moffatt
          it appears that the crankcase lower cover twisted on the tube. Will take it apart today.
          #208818
          jim-moffatt
            The upper flange was held to the tube by two 3/16″ aluminum rivets which had sheared, I replaced them. Its now ready to test.
            • This reply was modified 6 years, 2 months ago by jim-moffatt.
            #208829
              Sounds all all turned out well!
