Home Forum Ask A Member Johnson A-50 vs K-50
  • #167653
    APL
      APL
        APL
          The 4 photos above are of the two motors. The the one with the K-50 marked rope sheive is on the right.
          #167658
            Looks like the K (motor with gas tank) is on left and A on the right. What are the serial numbers on the blocks and sheave plates?
            #167659
              Also you could pull the props and read the part numbers on the inside of the props and look up the part numbers .
              #167664
              GARY
                Does either one have a tube running from top of crankcase to just above handle and back into the crankcase?
                • This reply was modified 7 years, 7 months ago by GARY.
                #167693
                squierka39
                  From the pictures they both look the same, I don’t have an A to look at but when I e seen them at meets I seem to remember them as noticeably smaller than a K. Oddly enough a guy on FB just bought a motor listed as an A-50, with an A-50 rope plate. When he picked it up it turned out to be a K-50 with A-50 rope plate. It does happen.
                  #167704
                  squierka39
                    Studying the cylinder block I going to say they are both A-50’s. The K has the area around the intake, near the spark plugs, bulge out. The A appears flatter.
