Home › Forum › Ask A Member › Johnson accessory or dealer only display?
  • #267335
    MIKE SIMS
      I would appreciate your opinions. Is this an accessory transom support or an dealer item for showroom display? Vintage era?
      It is approx. 7 3/4″ width.
      Johnson
      #267346
      hondaatc
        Looks like it was on a engine stand
        #267347
          Can’t say for that one, but OMC did sell transom protector plates.
          Screenshot-2022-10-09-164219
          #267366
          BRUCE REINHART
            Well I would think that is was a after market plate because I make these Mercury 10 Hurricane transom clamp plates
            #267375
            opposedtwin
              Well, you should put it behind your transom clamp pads and see if they  actually fit the holes in the device. I bought one of those mercury ones (not ftom bruce) and it does not fit the transomvlamp pads at all. The only mercury motor it fits is a mark 25.
              #267376
              opposedtwin
                Bruce,
                Can you post another picture of that mercury one with a tape measure  showing the distance from center to center of the pads?
                Thanks!
                Scott
                #267388
                MIKE SIMS
                  Bruce,
                  Did you create the original or did you use an original to make a mold that you use to recast them?
                  Whether it is a transom support or an engine stand support my question still stands. Accessory or dealer / factory display item?
                  #267408
                  opposedtwin
                    My guess is that these were never made by or for either mercury marine OR OMC.  I have never seen them in either accessory catalog nor do I believe Carl would have ever knowingly contracted with a vendor/supplier who also was a vendor/supplier to OMC, particularly anything with his name on it.
                    Therefore, I am of the belief they’re aftermarket. Who made them and when would be great to know.
                    #267409
                    bkrsdoz
                      I have a Johnson 3 HP transom plate. I heard they were aftermarket same as the factory accessory stands.
                      #267422
                      BRUCE REINHART
                        I cast the Mercury transom plates off a already made plate
