Home Forum Ask A Member Johnson AD-10 piston rings
  • #293354
    BAYER
      In search of piston rings for Johnson outboard AD-10 7.5 HP.
      Thanks
      #293359
      fleetwin
        There are a few different part numbers for these rings…  There is a part number for each individual ring, and there is a part number for a “ring set”  (three rings for one piston), will try to find the number for you…
        #293361
          Contact Otto Gas Engine Works at- otto@dol.net  or 410 398 7340. Also Member – Ed Elliott at-  ell92035nl@cox.net Tubs
