Home Forum Ask A Member Johnson CD-14 Frozen Pinion Gear-Shock Absorber
  • This topic has 44 replies, 11 voices, and was last updated 6 years ago by Don.
Viewing 10 posts - 11 through 20 (of 45 total)
  • #191217
    James Tapscott
      Thank you Labrador-guy. I already pulled the power head, drive shaft and pump housing. So I’m looking at the top of the shock absorber, which is still soaking in Evapo-Rust. If you have any advice on how to get the pinion gear off the bottom of the shock absorber, then maybe I could drive the shock absorber out from underneath with a wood dowel. Any advice much appreciated.
      #191219
      labrador-guy
        James the pinion gear pulls straight out, once the gears are out of the way. Try a couple screw drivers on each side. The shock absorber should tap out with a punch. Sounds like the rust is making things move harder than they should. Usually these parts fall right out.
        dale
        #191221
        James Tapscott
          Thanks Dale. Was just working on it and I got it to turn! Big screwdriver down the middle of the shock absorber with a wrench on it. Its turning pretty well now, but I can’t get either the pinion gear or the shock absorber to pull out. So back in the evapo rust to soak for another day. At least I now know I have a salvageable lower unit, so I’ll order all the gaskets, impeller etc.
          Thanks again.
          Jim
          #191230
            patience brings joyโ€ฆ let it soak ๐Ÿ™‚ 5.5 cd is a great little kicker and back-up โ€ฆ.. purrs all day
            I sold one I refurbished & converted to pump to a fellow next door to my cottage
            he still talks to me ๐Ÿ™‚ and runs that 5.5 on his fishing trips
            Joining AOMCI has priviledges ๐Ÿ™‚
            • This reply was modified 6 years, 2 months ago by JACQUES.
            #191233
              see pic with a round Briggs pump mounted on the back cross bar.
              5.5-Hp-Dec-2013-016
              5.5-Hp-Dec-2013-013
              • This reply was modified 6 years, 2 months ago by Mumbles.
              #191250
                That’s a nice-looking pump installation.
                #191259
                  Thanks again.
                  Jim
                  As previously stated, turn the gearcase upside down and drive the shaft out of the pinion gear using a large punch or small socket while trying not to lose the small Woodruff key which drives the pinion. If water was in the gearcase, these parts are probably rusted together so a big hammer and hitting it like you mean it should get these parts moving. A press will do it for sure.
                  Your pinion gear should be similar to the lower one in this photo.
                  Pinions
                  #191303
                  James Tapscott
                    Success!! Screwdrivers didn’t work, but punch got it out. Not as rusty as I thought. I guess running it dry of oil overheated it and the heat caused everything to seize up. Will soak all parts for another day and start cleaning up and order gaskets etc. Drive shaft and shift rod bearings look ok. I’d rather not replace them unless one of you experts insists otherwise. Once this one is back running I have similar vintage Johnson 10, Evinrude 15, E 18, E 3 and an old old Johnson 1.5, all in need of various repairs. Should keep me busy for a few years!
                    Thanks again.
                    Jim
                    #191326
                      ๐Ÿ™‚
                      #191583
                      gjonz
                        IIRC the shock absorber can be seen in the middle of the pinion gear. If need be drive it out with a drift. A little heat may help. I just used some Aerokroil on a stuck motor and it did wonders. Expensive but worth it.
                        Heck even if you destroy the pinion and shock absorber, there are plenty around.
                        Good luck.
                        Greg
