Home Forum Ask A Member Johnson FD 10 tight flywheel
  • #186600
    mercuryman
      I was about to give up getting flywheel loose. I would tighten puller tight as I dared hold the weight off motor and wack with hammer with other hand. Then I got help and made a flywheel knocker. I had a wide nut screwed down 1/2 way and tightened hardened bolt to flywheel. My helper held the whole wight of motor holding flywheel. Them I griped a 3 lb hammer with both hands and after two mighty wacks it was loose.
      knocker1
      • This topic was modified 6 years, 10 months ago by Mumbles.
      #186617
        What kind of puller were you using?
        #186622
          Funny, FDs don’t usually get that tight. I don’t think I ever had one that gave a fight against an OMC flywheel puller. (RDs, well, that’s another story….) If you tell me that knocker got it off when an OMC puller couldn’t, I will truly become a Believer.
          #186631
          mercuryman
            I have a heavy built Harmonic Balancer Puller. I can’t see any difference between OMC puller and HBP in the way they work. Both have a 5/8 fine thread bolt pulling 3 – 1/4 X 20 bolts. OMC cost $90 plus. How much torque can you apply before the 1/4 X 20 bolts break. I am pulling a 1 foot wrench as hard as I can and wedging long screw driver between 1/4 20 bolts. Maybe I could use a bigger wrench.
            • This reply was modified 6 years, 10 months ago by mercuryman.
            #186658
            squierka39
              The OMC puller comes with shoulder bolts that align the puller with the flywheel. If you use non shoulder bolts you can get the puller cocked, even just a little, and the tighter you make it the the more it wedges the flywheel. You could get some shoulder bolts for the puller you already have and get the same effect.
              Whacking while lifting works too.
              #186679
                soaking the crankshaft with some release agent a few days should help….. oddly enough the clear silicone spray used in snowblowers to stop snow and ice sticking seems to have great capillary properties. I just did my flywheel on a MQ11 and it came off with a bang !
                #186692
                mercuryman
                  Thanks for info now I understand to difference, I am going to try some shoulder bolts.
                  #186718
                    The OMC puller definitely makes a difference. I also use one of those electric impact guns instead of just a wrench/breaker bar on the puller screw….
                    #186736
                    Steve D
                      The original part number for those shoulder bolts/screws is 307641 to use with washers 307639 and this McMaster Carr option for the screws looks close.
                      shoulder-screws-mcmaster
                      shoulder-screws-ebay
                      OMC-Puller
                      #186887
                      2fast4me
                        Yes to the shoulder bolts, i also recently purchased the OMC puller and the harmonic balancer puller that i used for many years now sits idle.
                        2Fast4Me
