Garry,
Thank you, never thought about the shift shaft which it has. I fear going into the shed now with the heat so high. Just want someone to use it. I forget where it came from & have no use for it. Can’t do much without a kidney transplant now. Thanks so much.
Garry,
Just remembered this is from the Johnson 5hp I think with the carb on the side. Gave up on it as it had no compression & wouldn’t idle & run well 1949 maybe??
This reply was modified 4 years, 7 months ago by jeff-register.
