Home Forum Ask A Member Johnson HD 15
  • #285563
    Ken Marshman
      Hello.  New here.  I’ve recently acquired a Johnson HD 15 and I’m wondering if the motor is rebuildable.  The motor spins and does not appear to be missing anything.  I have the motor, tool bag, owner’s manual, and spare prop.   Is there a service manual?
      Ken
      #285565
      John Gragg
        Hi Ken,
        Everyone here calls this service manual ‘The Bible’. Unfortunately it’s not a free download, but for the $19.98 they ask it’s well worth it.
        In my experience it’s likely someone will offer to get you a copy, so maybe hold tight for a day or two.
        Good luck and welcome.
        Best Regards
        John Gragg
        RIverside, CA
        Just starting in the hobby, please be patient.
        48 Sea King 5hp GG9014A
        49 Sea King 5hp GG9014A
        48 Johnson TD20
        49 Johnson TD20
        54 Johnson QD15
        55 Johnson CD12
        #285567
        crosbyman
          Canada Member - 2 Years
          it was on  Garry Spencer’s  list of docs which is no longer available for free download  for members but  what is 20$ these days 🙂
          the file is quite large  the only way would be for a member with a file transfer  like dropbox to provide a link .
          https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
          see ex: pages   sorry magneto file is  over 2 meg    this site will not handle >2 meg
          before spending $$$ check  compression   head gasket  are cheap but a full rebuild may be $$$$  checkGC  for water  (may need  a reseal) etc….    great hobby  !
          #285570
            this site has some good basic “how to” tips on those motors…..
            http://pochefamily.org/outboard
            seakaye12
              Ken if you want to PM me your e-mail address I can send you the “Red Book” that these guys are talking about.  It would be sent through a free file transfer service called WETRANSFER.
              #285582
              Ken Marshman
                Thanks for all the replies.
                I am patient.  I would like to set this unit next to my 25 Evinrude for trolling.
                I will check compression.  What is a good pressure?
                GC will need a seal.  No water just old grease.  Motor was stored indoors and hasn’t been on the water for at least 5 decades.  I know the original owner.  Husband has been gone and wife kept it on a motor cart.  It could really use a paint job.
                I have discovered the Pochefamily site. Thanks
                1.  I don’t know how to PM.
                2.  As a member, is there a way to search the forums without tabbing through the pages?
                Thanks Ken
                #285583
                crosbyman
                  some engine run fine at 65-7- sp anything above  isn’t bad  …all depends on wear and TLC  (oil)   given to it
                  GC…. use john deere  corn head grease but  a good  grease clean up won’t hurt .
                  to PM  click on the  destination avatar on the side of page     select  message on the pop up screen     fill in  subject  title  then details    hit send…..done 🙂
                  #285621
                  seakaye12
                    Thanks Ken
                    Searching Forums for Members:
                    1. At the Menu above….go to MEMBERS ONLY/ ACTIVE MEMBER FORUM
                    2. Enter your search terms in the field that appears at the upper left of the page.
                    3.  The Similar Search Field that appears on the home page of the site  does NOT search the forums;  just public areas of the site.
                    #285629
                    Ken Marshman
                      Thanks for the search help.  Dave, had set me straight.
                      Ken
                      #285702
                      lloyd
                        70 to 75 psi  is good compression.
