Home Forum Ask A Member Johnson HD 25 coils
  • #25993
    greg-o
        Well, I don’t know what to make of that.
        By the serial number, it should be a 1946. 1946=491737 to 538800
        However, the model number pegs it as an earlier model, ie the HD 20 was the HD25 in 1946.
        So, I dunno
        #26000
          quote Greg O:
          Can I post pictures directly or do I need to be a member to do that?
          Of course you can post pictures here!
          Just copy the ‘IMG’ code on your Photobucket page and paste it anywhere in your post.
          #26001
            quote Chris_P:
            So, I dunno
            Probably had something to do with WWII. HD-20 was made till the war shut down outboard production in 1942. Then at war’s end, the 1946 HD-25 was born—probably using a bunch of pre-war parts stored in the warehouse. That could also explain the presence of the spark suppressors I’ve been talking about.
            #26041
              • This reply was modified 7 years, 10 months ago by Tubs.
              • This reply was modified 5 years, 6 months ago by Tubs.
              #26463
              greg-o
                Thanks. I appreciate it.
                #26470
                retiredoz
                  Serial # indicates 1946, last year for the HD-20. The HD-25 was also produced in ’46..
                  #31579
                  greg-o
                    OK, I am just getting around to getting back to this project. I just bought a magneto plate for a TD 20. Obviously the TD 20 plate won’t fit this HD20 motor. The coils and points are 90 degrees different between the two. The coils should swap out ok, but I am wondering about the Maverick spark suppressor. Should I use it on this motor, which had them, even though according to Johnson, it did not have them? I do not know what magnet rotor this motor has, or which cam. If I need to use the spark suppressor, which condenser should I use. I really hate soldering anymore than I have to on these coils. I will use a soldering gun with minimum heat, just enough to melt the solder. I figure if the spark suppressors are not used I would use the condenser that goes with that coil.
                    I really appreciate everyone’s help on this project. I think it will make a fine little motor. The original paint and decals are in good shape for it’s age.
                    #31585
                      The spark suppressors under the coils support the HD-20 model number.
                      #31587
                      greg-o
                        Frank are you saying if I use the coils from the TD 20 that have NO spark suppressors, I should use the spark suppressors on this HD 20 motor? And which condensers should I use?
