Home › Forum › Ask A Member › Johnson JW-13 3 hp Seahorse
- This topic has 23 replies, 7 voices, and was last updated 3 years, 8 months ago by
crosbyman.
July 29, 2021 at 1:11 pm #243877
Nice ’57 JW!
July 29, 2021 at 1:13 pm #243878nice motor!!
no big complexities… clean the carb check ignition and cracked coils clean the points, condensers may be shot…. change gc oil and impeller
tank inside filter may be clogged….remove inspect and clean it go fishing .. done !Joining AOMCI has priviledges 🙂
July 29, 2021 at 1:14 pm #243879see link
http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1957&hp=3&model=JW-13Joining AOMCI has priviledges 🙂
July 29, 2021 at 1:24 pm #243885Editing – looks like three of us were typing/posting at the same time – sorry for the duplication!
You will find exploded views and parts lists for your 1957 3 HP at the link below. These are simple motors so you may not need manuals. There is no telltale cooling water stream – just some spray about half way between the powerhead and the cavitation plate. Use gear oil (not grease) in the gearcase. Use 16 to 1 gas/oil mix. If it still has original coils, they will be bad – insulation cracked, etc., but if it’s been used in the last 20 or 30 years, the coils have likely been replaced.
DaveHere are the views and parts lists:
http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1957&hp=3&model=JW-13July 29, 2021 at 1:32 pm #243887Is that link to Garrys dropbox as he has requested numerous times it is not to be made public.
Maybe something has changed and I missed it. Don’t know.
July 29, 2021 at 4:01 pm #243897Opps – I guess I didn’t know it wasn’t to be made public – it was on a post here awhile back. I removed it from my post above!
DaveJuly 29, 2021 at 5:14 pm #243904Thanks to everyone for the prompt and numerous responses. All the information looks very helpful.
Side note: The http://www.marineengine.com link appears to just go to their website, not a private Dropbox?
If there are any good places to find old advertising and such, I would be interested in that as well.
July 29, 2021 at 6:22 pm #243914as a member….. you have access to…… MEMBERS ONLY….. INNER SANCTUM ….scroll down to .. LIBRARY……then GARRY SPENCER DROP BOX and you will find lots of info incl the need to have JOHNSON RED BOX you can download to service your JW and other oldies
find the book in this picture.. .1954 JW… much like yours 🙂 and the RED book you need
July 29, 2021 at 9:31 pm #243933Thanks to everyone for the prompt and numerous responses. All the information looks very helpful.
I just tried that same Marine Engine link from both posts above and and it went directly to your 1957 JW-13 at Marine engine – it should take you to a list of the various sections of your motor and then you click on the list item you need a parts diagram for.
When the exploded view comes up, scroll down and the parts list by number on the diagram is below it. Try again and read carefully what comes up.
For the red manual in the dropbox, see Crosbyman’s post above for instructions to get to to get to the member’s only dropbox from aomci home page.
DaveJuly 30, 2021 at 9:54 am #243954That is so beautiful….Too bad about the scratches in the tank, but that’s nothing…………Sure hope you plan on keeping its original finish and not repainting it….
Let us know any questions you may have about where to begin with this project. Don -
