Home Forum Ask A Member Johnson JW-13 3 hp Seahorse
Viewing 10 posts - 11 through 20 (of 24 total)
  • #243954
    fleetwin
      That is so beautiful….Too bad about the scratches in the tank, but that’s nothing…………Sure hope you plan on keeping its original finish and not repainting it….
      Let us know any questions you may have about where to begin with this project. Don
      #243958
      JdgMbi1
        Thanks, everyone for the additional information. Being a newbie to this little venture and the club, not quite up to speed on the benefits yet, so thanks for setting me up.
        Thanks, Fleetwin. I am keeping the exterior as is, just some wax and buffing. The mechanical is what I need to work on, though it has great compression when you pull the cord, so hopefully it won’t be a big overall.
        Below are some additional photos of the motor from all angles.
        Thanks again.
        #243965
        crosbyman
          I recommend you visit the marine.com place and copy off all sections of your JW parts list and print to PDF files then paper for safe keeping.
          Do the same for the RED book while it is available for easy downloads to PDF ,USB’s and paper .
          A local print shop can print off the 400 pages or so and spring bound them with plastic cover sheets in 2 x 1inch books for easy reading as the oldies virus invades your brain and your collections swells up in coming years. warn the wife if required ! 🙂
          #243966
          fleetwin
            OK, well I am assuming you want to actually run and use the engine, not just display it, correct?
            So, let’s begin at the beginning…How much experience do you have working on outboards?
            The first place to start is with the fuel tank, open the cap, have a look and a sniff inside…Is the tank clean, free of varnish and rust? Hopefully, because the tank is pretty much useless if it can not be cleaned out inside with relatively mild solvent. Don’t use anything too harsh that you might spill on the paint.
            Next, you mentioned the compression seems good. Pull the plugs and check compression on each cylinder. Don’t be concerned when you see relatively low readings, 70-80PSI, this is normal. The important thing is that the readings are about the same on both cylinders. Next, temporarily crack open the large lube drain screw on the bottom of the gearcase. You will probably see relatively dark gear lube, which was normal for the time. Newer lubes are more golden in color. Milkshake colored lube is concerning, raw water is trouble. You only need to crack the screw open for a second or two to get a read on gear lube condition, no need to drain it out at this time…..Reinstall the screw after a few drops have dribbled out.
            Next, you will want to have a peek at the ignition…Usually, an old low hour engine like this has its original coils, which have probably cracked over time and must be replaced. You can peek inside without removing the flywheel completely. Simply remove the four screws that secure the recoil starter, now you will see the top of the flywheel….There are three flat tip machines screws that secure and inspection cover, remove those screws and the two cover plates. Now, peek inside, are the coils all cracked up? If so, the ignition will need to be overhauled.
            You will probably need to pull the carb apart, clean it out and rebuild it also, there is a tank filter and valve that should be removed and inspected also…
            Finally, you will want to remove the gearcase, inspect and replace the rubber water pump impeller….
            Needless to say, this is just a quick outline of things you will need to inspect and service in order to make this engine a “reliable daily runner”. We can go into more depth as you approach each project. For now, do the compression test, inspect the tank, and gear lube….Don
            #243978
            JdgMbi1
              WHEW! Thanks, the in-depth outline…Need to digest it a bit and formulate some further questions. This is what I know so far:
              Correct. Would like to have it running
              Pretty much outside of growing up with boats, my experience of working on them is almost null!
              The tank is very clean.
              I just ordered a compression tester so I will get on that.
              Thanks
              #243979
              crosbyman
                Fleetwin.. I hope you did a “copy paste and save on that text ” for future JW owners 🙂
                #243980
                JdgMbi1
                  Just downloaded and printed the Johnson Red book (thank you Garry), and will start to do some light reading over the weekend.
                  Again, thanks to everyone for the more than ample information to get started on this little project-I’m excited.
                  #244043
                    I agree. That is PERFECT to start with! He should keep that as a permanent file!
                    #244045
                    fleetwin
                      Guys, tell me how to “keep that as a permanent file”…. Haven’t made the leap into this century quite yet….
                      #244049
                      crosbyman
                        well I guess you can just copy pate to a saved word document and bring it up as required
                        as to storage on this site we would need some kind of yellow brick road feature to guide new comers to their individual JW AD CD QD FD etc… castles where basic check lists would be available
                        but that could get a bit complicated with endless makers, models, years, hp,
                        copy paste from Word may be easiest 🙂
                        • This reply was modified 3 years, 8 months ago by crosbyman.
