Home Forum Ask A Member Johnson LT-37 Lower end
  • #291334
    Doug Schruth
      I am trying to remove the lower end unit from the brass tube on my Johnson LT37.  I have the clamp bolt off but it will not budge.  I’ve soaked it in ATF/Acetone and also other penetrating oil but still no movement.  I don’t want to hammer it for fear of breaking the aluminum housing.  I’ve also used a plastic “wedge” to attempt to open the clamp held by the bolt just a little but that doesn’t help either.  Haven’t tried heat yet.
      Any suggestions would be appreciated.
      #291335
      Tom
        Have you removed the exhaust cover and disconnected the water tube?
        T
        #291336
        Doug Schruth
          Yes, the exhaust cover and water pump module has been removed.
          #291344
            Have you tried twisting it a bit from side to side to see if it will break free? Tubs
            A "Boat House Repair" is one that done without having tools or the skills to do it properly.
            #291345
            Doug Schruth
              Thanks for the reply. I have tried a little but after it soaks for a day or so I’ll give it another try. Just working my way up. Thanks for your suggestion. New at this so taking my time.
              #291346
              joecb
                A little heat will help.  Warm up the aluminum casting, then grab the brass tube with a cold wet rag, try twisting back & forth. Ok to heat with a propane torch if you GO EASY and don’t get too hot. If concerned, use an electric heat gun.
                #291347
                Doug Schruth
                  Awesome, great advice. I have just the heat gun to use. If that doesn’t work, got fire. Sure not in a hurry. Winter project.
