Home › Forum › Ask A Member › Johnson Model ” A” Cast Aluminum Gas Tanks
- This topic has 8 replies, 4 voices, and was last updated 1 year, 11 months ago by
Tubs.
September 23, 2024 at 8:19 am #291022
What year did Johnson switch from the cast aluminum to the stamped gas tanks.
My 1923 model A # 4215 has a cast tank.
I found a 1924 model A # 10019 with a stamped tank.
This suggests the Johnson model A changed to the stamped tanks between 1923 & 1924.
Thought I had info on this in my notes…….somewhere.
September 23, 2024 at 8:24 am #291024Critcal error message attaching picture, trying again.
September 23, 2024 at 9:02 am #2910261923 was last year for cast tank,steel driveshaft tube,steel air horn,steel steering rail and tiller handle as well as a few other parts common to early A models.The cast tank was discontinued at about serial number 5000
September 23, 2024 at 9:10 am #291027Thanks Stanley.
Interesting, I didn’t realize Johnson produced the model A in both cast and stamped tanks.
Is there any information on the serial number range for the model A’s.
T…
September 23, 2024 at 9:17 am #291029A model serial numbers from #506 to #20,000.1924 was only year for that style tank.Also for brass steering rail,brass tiller and brass air horn.
September 23, 2024 at 9:40 am #291030Again, interesting info.
My 23 A has a brass steering rail & tiller handle but a steel or what appears to be a steel plated air horn.
The 24 A has a steel rail and tiller handle, and missing air horn. I’ve not seen the 24 close up yet, possibly painted over brass.
Posted pictures are “erroring out” this mornning.
T..
September 23, 2024 at 9:53 am #291031It’s not unusual to find later model parts used as replacements on early A models.The early (1921-1923) models all had nickle plated drive shaft tubes,but many were replaced with the later nickle plated brass ones because of rust damage.The steering rails and tiller handles,carbs,carb levers,gas bowl nut and fuel line are also often later replacements/upgrades.That being said,who knows what happened to left over parts when change over to new model production occurred.
September 23, 2024 at 10:34 am #291032The cast tanks were replaced with a similar shaped stamped and welded seam aluminum tank that looked similar to the cast tank for a short time. They then changed over to the more familiar balloon style aluminum tank.
September 23, 2024 at 11:47 am #291039
Motor on the left is S# 9959 having the stamped tank. Motor on the right it $# 5449. Likely one of the very last motors to come with the cast tank. Tubs
