Home Forum Ask A Member Johnson MS-38 carb linkage
  • #238778
    BRUCE REINHART
      HI to all
      I am working on a Johnson MS-38 and would like to know if anyone has a picture or a parts manual that shows the linkage between the carb and the stator plate
      #238792
        This is off a MD-38……… perhaps the same thing.
        DSCN8806
        DSCN9326
        BRUCE REINHART
          Thank you very much
          Were the spring goes over the brass shaft there must be something that it butts against to put pressure back onto the plate end
          On the one I am working on the spring just floats along the shaft
          I will make up a small collet or stop on the shaft
          #238805
            I believe there’s just a tiny washer and a piece of wire thru the rod, that positions the
            carburetor end of the spring. If I remember correctly, this setup is so that if you
            retard the magneto past the point where the throttle butterfly closes, the spring will
            compress instead of bending your butterfly.
