I just went to pull the flywheel off an OA-55 I picked up yesterday. Pulled the rope sheave & crank nut off, grabbed my puller & bolts…..and it appears that the holes are 1/4 -24 thread, if I’m reading my thread pitch gauge right. Am I correct? I vaguely remember finding some of this size on a old Harley that I did some resto work on for a guy back in the day. Any ideas to save me byying a sack of expensive scooter hardware to use only three would be greatly appreciated.
Thanks!
Jim
Your motor was built in a time before thread sizes became standardised and manufacturers could use whatever thread they wanted. Those threads aren’t 1/4-24 but close. They should be 14-24, which is just a few thou under 1/4".
Here’s a link to a previous thread on these threads:
Thanks, Mumbles! Learned something there….I always thought that 1/4" and #14 were the same…
Tubs told me how to make a flywheel-popper-offer which worked great. Nut w/bolt welded in, tighten on crank, lift flyweel and two whacks with a hammer…
Now I’m on a mission to find a coil. My new Merc-O-Tronic says it’s bad.
