Home › Forum › Ask A Member › Johnson of Oakland, Kaminc, and Stannus Props
- This topic has 9 replies, 7 voices, and was last updated 8 years, 4 months ago by chris-p.
November 28, 2015 at 8:16 pm #3073November 28, 2015 at 9:56 pm #27760
I hope you bought em!
I would have to look up the numbers. I have a few Oakland props, for my Speeditwin.
November 28, 2015 at 10:58 pm #27763If the bore is tapered, they’ll be for inboard shafts but the smaller props also used a straight bore with a pin.
The old rental clinker boats from around here had small props on the brass shafts. I guess it was a good match for the single cylinder Briggs motors that were spinning them.
I have one with a short piece of shaft out in the shop so I’ll measure it when I go out there.
November 29, 2015 at 12:53 am #27769It would be helpful to have an idea of the application of these props. If they are for outboard motors and can be of use to members, I will pick them up.
I have the following application table for Johnson Propellers that someone posted awhile ago, but no propeller numbers, only dimensions. If someone has a list of applications by prop number, please share!
November 29, 2015 at 1:40 am #27773They all look like left hand props, so they would be mercury or Evinrude speeditwin/speedifour 22.5/33 hp"
A couple look similar to ones that I have for my speeditwin. The kaminc is probably mercury.
I would grab them and post the ones you can’t use here. I would be interested in Evinrude props if available.November 29, 2015 at 3:57 am #27780Anonymouskaminc is keikheafer aero marine inc. mercury for sure.
December 2, 2015 at 4:01 am #27909Well I went back and made a deal. Turns out an older couple brought them in; they had owned a marine service business and these were take-offs for repair/replacement. A couple have bent tips or chips off the trailing edge, but most appear in good shape.
I have one ID’ed for sure. It has the OMC part 100726. The 1945 Evinrude Service manual says this is the standard for Models 905-907 Elto Special Speedster 9 HP 1931-1933.
Others to be identified:
Michigan KD5 (8.5" diameter, have not measured pitch yet)
Kaminc MC 4634 7" x 10 (marked)
Stannus 1477-1 8.5" diameter
Stannus 1477-2 8.5" diameter
Stannus 1429-1 8.5" diameterUnmarked 9.5" diameter
Johnson of Oakland 8 1/2 (marked 8 3/4") x 12 1/2 (marked)
Johnson of Oakland 8 3/4" (marked 9") x 11 1/2 (marked)
Johnson of Oakland 8 3/4" (marked 9") x 11 (marked)
Johnson of Oakland 8 3/4" (marked 9") x 13 (marked)December 2, 2015 at 1:12 pm #27916The KD5 is listed for a KG9……8 3/8 x 14 $18.90 new
December 2, 2015 at 1:29 pm #27917It looks like the Kaminc’s are quicksilver props for KG7H’s or MK20H’s. If you bought them I’d be interested in purchasing them from you.
December 2, 2015 at 9:09 pm #27943I too collect these. Any you are interested in selling please PM me.
