Home Forum Ask A Member Johnson outboard Model OK-10 ?
  • #71269
    kevinrude
      OK-10 serial numbers, per the above chart, were 46463 – 46481 so Olivier’s 46479 was the 3rd-to-last one made out of a total run of 18!
      #71355
      olivier81321
        Wow that’s great info, thank you guys! I had no idea is was such an uncommon model…
        #71356
        oldelto
          1940 OK-10 total 195 made and OKL-10 total 22 made.
          #71360
          kevinrude
            quote oldelto:
            Oh yeah, I see it now — there were a bunch more OK-10s earlier on in that list. Still, it is the 3rd last one!
            #71368
              Third to last one in that particular run. There’s more of them.
              Looking at these snips you can see they would make one or more models of a motor before switching to another model. Canada was at war then so they could have been filling orders as they came in or had problems obtaining parts for them on time. Looking at the numbers, they would build a few of XX model before coffee break and then switch over too XX model until lunch and then finish the day building XX models. No boring repetition for the workers in that factory!
              HayFever
                Hello Mumbles—Just joined as temp guest — have been net surfing to find most I can about my inherited LT37– Grandad and I used it in the early 70s– found in the boathouse this summer ..
                All apart — JUST freed up the one seized cylinder after weeks — final try — built a spring tensioned puller on backside to connecting rod pin — and boiled , submerged in fiATF filled trash can– inside a ductwork ‘kiln’ i built — tiger torch, anyway OUT — no scoring– just residual varnish… ( i am retired engineer– all auto)
                I love the files on serials you have posted — The LT37 (aka “The Bee”) was built in “Peterboro” and has a serial “33072” — wondering how many made, can the serial tell date of build, etc
                Thanks — PS We have boated, cottaged — on family island “Strathaven” — started post WW1–
