Home Forum Ask A Member Johnson Outboard Motor
  • #171834
    dbacken85
      Found an old Johnson motor in grandfather’s shed. Was wondering what the value was for it. It says “sea horse 5 1/2. Attaching picture.
      20190323_121908
      • This topic was modified 6 years, 1 month ago by Mumbles.
      #171841
        1958, looks nice. A desirable motor among collectors. Condition and location are everything.
        #171851
        fleetwin
          Unfortunately, old outboards really don’t have much value….
          Do you have a boat that you can use it on, or would you prefer to find it a good home?
          Like Frank says, condition is everything…Is the engine’s fuel tank still there also? If so, look inside to see if it is clean….These engines use special fuel tanks, so having a clean tank will help increase the engine’s value. But, if the tank is rusted/fouled inside, it is worthless.
          No matter how nice physically the engine might be, it will need considerable servicing to make it a: reliable daily runner….
          The ignition system, fuel system, water pump, and gearcase will all need to be inspected and serviced.
          The engine surely “looks to be” in nice cosmetic condition which will help its value….
          So, I would “guesstimate” its possible value in the range of $100-$400 depending on all the issues I mentioned.
          Where are you located? Perhaps there is a club member nearby who might be interested….
            In my area a 5.5hp would be worth about $100 to $150 or so in that condition, not running.
            After a full tune up, and running with a tank in the $250 to $350 range.
            Hope that helps.
            As mentioned, not a lot of value. Probably more sentimental value as it was your Grandfathers! Might want to keep it for that reason alone, and get it running. Lots of knowledgeable members on the forum that can help you out.
            #171854
            dbacken85
              I do have the fuel tank. Havent looked to see the inside condition. And I’m located outside of Memphis, TN. I didnt think it would hold much value. Just not sure if we want to put the money into restoring it at this time.
              #171887
              fleetwin
                Well, it would surely make a lovely decorative piece as well, perhaps in a man cave or den area. Just remove the plugs add some oil to the cylinders then crank the engine over to spread it around. Do a nice wax job to the hood, try to avoid the decals though. Be very careful with the plastic emblem on the front of the hood, it is easily cracked and hard to find.
                If the inside of the tank is in good shape, add some two stroke/lightweight oil inside and swish it around. Do not store the tank on a concrete/cement floor, hold it off the ground with a couple of short 2x4s. Use some of the oil on a rag to apply a protective coating to the outside of the tank.
                #171909
                crosbyman
                  that hood & body should look like a million bucks with some light rubbing compound and 2 coats of car wax..
                  has stated careful with the decals and plaques
                  why not start yourself a nice hobby…. . if the tank is shot you can always convert the motor to a fuel pump or… find a good 2 line gas tank
                  the book CHEAP OUTBOARDSs will tell you all you need to know … including mounting a fuel pump if you go that way
                  https://www.goodreads.com/book/show/24088031-cheap-outboards
                  if the engine is not seized (could be just stuck but not seized) I m certain Grandpa took good care of it by the looks of it …..$150 will get you a great smooth trolling motor
                  lots of utubes and help available !!
                  • This reply was modified 6 years, 1 month ago by crosbyman.
                  #171911
                  olcah
                    If a tank is not terribly rusty it can be saved by a simple electrolysis method. I think the original two line tank is simpler than running with a fuel pump. They work very well.
                    #171913
                    crosbyman
                      Just a question of choice … pumps are not that hard to do , they work fine , not expensive and easy to fix
                      #171946
                      outbdnut2
                        If the tank is not rusty inside and holds pressure (let it sit in the sun awhile and then loosen the cap and see if you hear pressure releasing)the tank could be worth up to $100.
                        I’ve got a couple of those 5-1./2 HP motors. They were made in that configuration with changes in the color of the case from 1954-1958. They continued into the mid-1960s with changes to a single line tank and a thermostat in the cooling system.
