Home › Forum › Ask A Member › Johnson PO-15 Magneto
  • #46523
      George, I sent you a PM….. Thanks!
      Mumbles, thanks for the great photo work!
      I was always leery about removing the flywheel
      by backing off the nut against the rope sheave
      on that style set-up…. I could see the sheave
      breaking easily!
        George, is your PM box full. I sent you two PM’s, but they’re still in my
        "Outbox" ?
        George Emmanuel
          Tom,
          I only check my messages about 1 time per day and I did get yours and I responded. I read some of the thread on the spark plugs. I quit using Champions…I had issues with them in other motors. I now use the NGK AB-7 with great success. The Champion D-9 and the 509 are the same and work great in PO’s. It is suggested to close the gap on Evinrudes of that era, so I run the Evinrudes at .020 and the PO at .025.
          George
          #46604
            George, good to know the spark plug gap, and the alternate NGK plugs
            … did not have that in my notes yet. Thanks!
              If you go to this site you can find alternative plugs for everything listed in its data base. After the list appears, click on one of the plugs listed to find alternatives for it or just click at the top left to start over.
              http://www.sparkplug-crossreference.com … HAMP_PN/D9
              Isn’t modern technologie marvelous? ☺
              #46625
                Thanks Mumbles….. some of those brands I’ve never heard of!
                  Mumbles asked
                  quote :
                  Isn’t modern technologie marvelous?☺
                  I typed in "Champion R7" and was told it wasn’t in there database. . . 😮
                  To err is human – bun to really screw up requires a computer – anon.
