Brian,
Glad to hear you got that sorted. The PO-15 is probably my favorite motor. It starts easily and dependably once you get used to the starting procedure. Lots of fun to run and get to know. They will idle down pretty well with some carb/spark adjustment and will shut off if you fully retard spark as well, so I don’t often use my kill switch.
Make sure you bring extra fuel along as they are thirsty!
David Bartlett
