Home › Forum › Ask A Member › Johnson POs
  • #211447
    jpe1965
      Have two Johnson PO outboards that belonged to my father. They haven’t been started in a few years (thinking about 5 or so) and would like to sell them. Am unsure as to how to exactly proceed as I would like the listing to be accurate, however, I am guessing they would need some TLC/tuneup to run. Here are some pictures of them for reference. Any suggestions or thoughts would be greatly appreciated. Thank you.
      IMG_8782
      IMG_8787
      • This topic was modified 6 years, 1 month ago by Mumbles.
      #211467
        At the minimum, your should state whether or not they turn over with compression,
        or if the engines are stuck.
        Also note any missing or broken parts, or welded repairs.
        Location will probably dictate the asking price.
        They’re fun engines to run, and not worth a fortune, so many in the club would probably buy one.
        Put a free For Sale ad on the website’s classifieds.
        WAYNE
          Johnson PO’s are quite common and heavy. Both those things negatively affect value. However, the PO makes up for these short comings by being a reliable antique outboard that will put a smile on your face every time you run it. My opinion is to always post as many good quality photos as possible. The model and serial number are on the rope sheave on top of the motor. That will tell us what year your motor is. You can post that info here and we’ll tell you what it is.
          The other way to go is to get the motors running yourself and enjoy then. They are surprisingly easy to get running.
          https://youtu.be/VT9WNaGWFnM
          Wayne
          Upper Canada Chapter
          uccaomci.com
          #211522
            8:1 fuel mix! Yes, that was eight to one.
            #211547
            jpe1965
              Thank you very much for the comments. Much appreciated. I know my father had mentioned they weren’t worth a lot, but am sure he would have wanted someone to enjoy them as he did for so many years. I will check the compression and do a more thorough inspection of the parts. Thinking local is probably best. Thank you again.
              #211548
              David Bartlett
                Where are you located? That will help generate interest.
                As Wayne said, they are heavy, but I find the “Fun to Weight” ratio to be favorable. A total blast to run!
                David Bartlett
                #211549
                jpe1965
                  Located just north of Chicago. Gleview, IL.
