Home Forum Ask A Member Johnson QD-16 base gasket
  • #283207
    Steve Martin
      I’m assembling a QD-16 10hp. The parts manual powerhead group shows a 303892 base gasket and the driveshaft casing group shows a 377070 gasket at the upper surface.  That would seem to indicate they would be stacked on top of each other which makes no sense to me.  Can anyone shed some light on this?
      #283209
      aquasonic
        I don’t know about the 1955 QD-16, but the 1954 QD-15 actually has two separate base gaskets for the powerhead. I’m certain that someone with experience with the QD-16 will be able to answer this question. Fleetwin will know this.
        Improvise-Adapt-Overcome
        #283210
          377070 is a gasket and baffle kit with a stainless steel baffle and 2 thin gaskets which replace the original gasket.  The idea is to keep the exhaust away from the lower crankshaft seal.  Good idea I suppose but doubtful that it did much good.
          #283238
          Steve Martin
            Thanks Frank. I’m unclear why both part numbers are shown for the same application on the two drawings.
            #283243
              Unclear for sure. I can’t see your parts book, but I’m surprised that 377070 gasket and baffle kit appears on a 1955 QD-i6 parts book, or for that matter, even compatible with the 10 hp.  That mod came about in later years in response to powerhead failures on the 15 hp due to crankshaft seal failures.
              #283247
              Steve Martin
                Actually it shows a gasket only with part number 377070 –  no plate and second gasket.  Confusing.
                #283249
                Steve D
                  I was confused by that too…
                  1955-Johnson-QD-16-10-HP-Parts-Manual-pg8
                  1955-Johnson-QD-16-10-HP-Parts-Manual-pg10
                  1955-Johnson-QD-16-10-HP-Parts-Manual-pg11
                  #283254
                    303892 supercedes to the current P/N, 304588.
                    I can’t find anything for 377070.
                    #283255
                    Steve D
                      Shows just a gasket in the manual but actually a baffle and gasket kit as Frank mentioned. Edit: A ’56 manual I just checked shows 303892 on the power head group page and exhaust housing group page but no baffle.
                      377070
                      #283257
                      Steve Martin
                        So what’s the consensus on the correct part(s) for the QD-16?
