Home Forum Ask A Member Johnson QD-17
  • #1525
    shoestringmariner
      Going to look at a 1956 Johnson QD-17. Anything I should be aware of or look for with these? Owner will let me do a compression test. I’m expecting coils needing replacement & the usual revival stuff…but is there anything else to look for?
      #16316
        Loose wrist pins. Check them while you have the plugs out.
        #16320
        fleetwin
          US Member - 2 Years
          OK, this 10hp has the larger 18hp style gearcase, which is a good thing. Ask the owner if you can crack the lower gearlube drain screw to check for water. And, like Frank says, check for loose/sloppy wrist pins. Ask the owner what fuel/oil mixture he is using, if he says 50:1, you might be concerned.
          These are pretty solid engines, other than possible wrist pin issues. Be sure to check the normal stuff, look for bent/cracked castings, signs of overheating, etc.
          #16353
          shoestringmariner
            excellent, thanks much guys!
