Home › Forum › Ask A Member › Johnson RDSL-21 mercury Switches
- This topic has 42 replies, 9 voices, and was last updated 3 years, 2 months ago by
Tom Alexander.
February 13, 2022 at 1:01 pm #254550
Well, it sure can be tricky to judge cooling system performance on these engines for sure. Just a few comments, first using an external water source connected to the side bypass cooling cover doesn’t provide too much information. The pressurized water acts as the water pump, so a bad/worn water pump can not be judged using this external pressurized cooling water source. Next, I am concerned about how deep your gearcase is immersed when you run the engine in a bucket, I don’t understand your written description. The gearcase must be immersed so that the connection line between the gearcase and exhaust hsg/extension hsg is under water. You mention that water pump pieces were replaced. It is extremely important that there is a good seal between the SS impeller plate and the gearcase hsg surfaces. These areas are rather thin, so erosion/compromised casting areas will create a possible air leak under the pump. Were all the threads for the water pump screws in good shape? No oversized screws or other shoddy repairs? Usually, these issues only occur on salt water engines, but they can occur on fresh water engines also. I am assuming you used new OEM water pump pieces.
You are so right about pictures/videos being worth a thousand words, especially my words. So, post a video of the engine running in a barrel/bucket for us if possible.
February 15, 2022 at 12:25 pm #254656Hi Fleetwin: Sorry for the late reply. I am also restoring a 1953 (we thing, builders placard missing) Mercury Boat Co. Ski Tug. This is a small mahogany utility with a Gray Marine inboard. No relation to the outboards co. or the auto co. The engine went back into the boat Sunday and it has taken my attention until it is aligned etc. I have a video of the Johnson RDSL-21 spitting water from the ‘exhaust water’ port and will try to get it ‘up’ somehow so it can be viewed. Do you happen to know what temp the cylinder are supposed to run at? They seem to get hot quickly maybe too hot? I have only run the engine for a few minutes at a time with long periods between those ‘runnings’. Thanks Tom Alexander
February 15, 2022 at 12:37 pm #254658Crosbyman: I have a downloaded copy of the ‘Red Book’. I find it a bit cumbersome to use but there is a hell of a lot of info in it!
Looking closer at the Evinrude video that mumbles attached here (If I only knew how to do that!) I don’t think I am getting that magnitude of water flow at all. If I hold my hand is the flow stream, at idle it gets wet but not dripping wet. Is there a way to test the thermostat with hot water on a stove like the old days when we used to always suspect the thermostat in ours cards of non operation?
February 15, 2022 at 4:23 pm #254674tom… I had my book put in 2 binders (about 200 pages each and a spring binding lets it sit flat on the work table )
I added plastic cover sheets front and back for wear protection and had the main front page copied for the 2nd book face page. looks like 2 books now 🙂
water ouput… I think a good part of the water goes all the way down the exhaust housing what comes out should not be so hot you can’t stand it … if lukewarm I think all is well
February 16, 2022 at 8:56 pm #254761Hi Fleetwin: Sorry for the late reply. I am also restoring a 1953 (we thing, builders placard missing) Mercury Boat Co. Ski Tug. This is a small mahogany utility with a Gray Marine inboard. No relation to the outboards co. or the auto co. The engine went back into the boat Sunday and it has taken my attention until it is aligned etc. I have a video of the Johnson RDSL-21 spitting water from the ‘exhaust water’ port and will try to get it ‘up’ somehow so it can be viewed. Do you happen to know what temp the cylinder are supposed to run at? They seem to get hot quickly maybe too hot? I have only run the engine for a few minutes at a time with long periods between those ‘runnings’. Thanks Tom Alexander
Well, I think these engines run relatively cool. The exhaust cover should always be relatively cool, maybe warm, but never hot. Engine temp is usually checked on top of the thermostat cover and should not get over 165 F. Sounds like your engine heats up pretty quick, which isn’t normal. Will wait for your video
February 16, 2022 at 9:10 pm #254762No luck finding someone to show me how to put vid on youtube yet. The google instructions don’t make sense. But… today an old outboard guy came over and while he is a true blue mercury guy, (been rebuilding and racing them since the fifties) he told me that as far as he is concerned the engine is cooling well. We did have a linkage issue, solved by adjusting the mechanism that shifts F-N-R and the ‘indents’. Day by day I am feeling better about this. Confidence is also growing. So, with you guys help the Mercury switches and solenoid issues have be laid to rest and I will set up a thermocouple or RTD in contact with the thermostat housing and see what that shows. I am a retired process engineer and seem to have a bit of this measurement stuff still laying around! Thanks all!! Tom Alexander
February 16, 2022 at 10:37 pm #254763Well, I finally got a bit of guidance on posting videos on youtube. First one went on, it’s only about 15 sec or so but it is on youtube now. It is called ‘Johnson outboard first start’. Seems to be a lot of these so IK hope anyone that is in treated in seeing it can find it!! Thanks Tom Alexander
February 17, 2022 at 11:01 am #254784Click on “share” and you’ll get a link to your videos.
https://youtube.com/shorts/iRHqUHoYbbE?feature=share
February 17, 2022 at 12:09 pm #254791Where is ‘share’? Here on AOMCI or somewhere on the youtube site? Sorry to be sop dumb about this! Thanks Tom Alex.
February 17, 2022 at 1:07 pm #254792A "Boathouse Repair" is one that done without having tools or the skills to do it properly.
