Home › Forum › Ask A Member › Johnson Sea Horse 10
Viewing 10 posts - 1 through 10 (of 21 total)
  • #176534
    bevanchak
      Hi, I am not an enthusiast, however, while cleaning out my father-in-law’s garage attic, I came upon what appears to be a green 1954 Johnson Sea Horse 10. It has literally been stored for decades and I do not know with certainty if it starts. That said, it is in fantastic condition and based on its condition, I believe that someone knowledgeable with outboard motors could get it up and working. I came upon this site and thought that I would ask if anyone can advise me on its possible value or if there may be any interest in it. It’d be great for someone to be able to enjoy it.
      IMG_4238
      IMG_4241
      • This topic was modified 7 years, 3 months ago by Mumbles.
      #176537
      amuller
        It looks outstanding. Easiest and most important test: Does it turn over or is it locked up. What happens when you pull on the starter rope handle?
        Is there a tank with it?
        I would not expect it to run without the ignition being serviced: points cleaned and adjusted; very likely new coils and condensers. This would be routine for an old OMC motor. Would need a new water pump impeller.
        Generally speaking these motors don’t have a lot of value simply because there are so many of them around. In Minnesota, $50-100 for an average example. But yours looks above average–original unrestored. Gotten running, and with a matching tank, could possibly fetch several hundred.
        Others here will know better than I.
        • This reply was modified 7 years, 3 months ago by amuller.
        #176540
        tinkerman
          What part of the country are you in?
          It's a jungle out there.
          #176541
          bevanchak
            Pittsburgh, PA
            #176544
              Wow, what a beauty. That one should be worth some extra $$$.
              #176545
              tinkerman
                lol title out of my driving range but sure looks like a good one, as long as the internals are good
                #176547
                Randy in Tampa
                  That really is nice, if it was in Florida I would buy it from you in a heartbeat 😏
                  Rotary valve Johnson’s Rule!
                  #176550
                  benji41
                    Me too Randy
                    Jim Benjamin
                    #176551
                    olcah
                      I normally have no use for motors that are not run but that one looks like it dropped out of the 1950s dealer showroom. Not worth real big $$ but it It belongs in a museum. If there is a marine/boat museum in your area I suggest it should be offered to them.
                      #176556
                        Normally oldies go for 50-75-100$ that one is superb and could fetch $200 easy or more
                        try to sell it on EBAY …start at $600 you never know They do need $125-150$ worth of refurbish for the carb , electricals, pump, maybe a gearcase reseal if you do the work
                        really nice motor
