Home › Forum › Ask A Member › Johnson Seahorse 5.5 CD10 or C11
- This topic has 20 replies, 7 voices, and was last updated 1 year, 9 months ago by
fleetwin.
June 21, 2023 at 10:08 pm #277216
Here is a better picture of the manufacturer’s tag.
June 21, 2023 at 10:46 pm #277223CD-10 and CD-11 are both 1954 models but I’m not sure what or if any differences are in them. Maintenance parts such as points, condensers, coils, carb kits and water pumps are readily available and were used on later six horse motors.
One thing to remember, this motor needs a 16:1 fuel mix to survive. Not 24:1 or 50:1 as 1964 and later motors used.
June 22, 2023 at 8:04 am #277228if you plan changing the impeller it is a bit tricky because you need to pull the powerhead by taking out 7 bolts, disconnecting the throttle linkage and fuel hose
it sounds complicated but it is not. pulling the PH may… damage the base gasket so a new one is needed…work carefully .
18-3001B – water pump kit for Johnson/Evinrude 5.5 hp 1954-55, Evinrud – VintageOutboard.com
As a AOMCI member you would have access to the maintenance 400 pages + ” bible” for your oldy. It containsall you need to know to keep your engine going another generation …or two or three
AOMCI Membership is worth the price of the book !! you can download and print & bind locally
see typical pages on dropping the gear case
June 22, 2023 at 8:18 am #277232so lots of help available here to get you going… btw the ignition needs a good look into to refurbish coils concensers plug wires etc…old coils crack up …all easy stuff to repair with parts available.
June 22, 2023 at 8:41 am #277238Most all parts can be found for this engine, if not new, than used or “old new stock”. I would start by checking the basics, like compression and spark. Then I would drain and inspect the gear lube. Have you had any experience working on outboards?
Another thing to consider is that you will need the two line pressure tank for this engine, do you have it? If so, have a look inside to be sure it is not fouled or rusted from old fuel being left inside it for a long time.
June 22, 2023 at 9:13 am #277239Perhaps they had left over CD-10 ID tags when they switched
over to CD 11 models mid year, and re-stamped the tag.Prepare to be boarded!
June 22, 2023 at 9:17 am #277240good points ! check for pin holes in the tank !!! mine dumped 5 gallons out the rear drain while the boat was on my tilted trailer.!
if and I say if you do not have the tank or wish to purchase one…the engine can be converted to pump…but ” one step at a time! “
June 22, 2023 at 7:03 pm #277269Fleetwin…thanks for your response!
I do not have any experience with restoring outboard motors. I did restore a 1984 John Deere 210 lawn tractor a couple of years ago, including rebuilding the engine. My background is in power generation engineering so I have a good sense of machinery and equipment repair. I was hoping to learn from those that have restored outboard motors. I think I’ve heard of some enthusiasts that actually open their shops to help individuals restore their motors.
Regarding the fuel tank, it was stored with fuel in the tank and it was rusted beyond hope. Are there any aftermarket tanks that I will be able to purchase?
June 22, 2023 at 7:07 pm #277271Hey Buccaneer…your explanation of why this motor’s ID tag might have been double stamped seems very plausible. Great thought!
June 22, 2023 at 7:11 pm #277272Crosbyman…thanks for the response. I guess I’ll have to cross that fuel tank bridge when I get further along. I was hoping there was some type of aftermarket tank.
