Home Forum Ask A Member Johnson seahorse
Viewing 6 posts - 21 through 26 (of 26 total)
  • #25725
    lotec
      I had a feeling the model # on the block would be different, what is the serial # on the block? My guess is it will show up as a 1941 production #. The typical TD-15 would be the same as the later TD-20s with the recoil (as illustrated in the photos Gary posted) only the motors were entirely painted silver. Decal would be red with white letters.
      Just curious, are you thinking of restoring the motor back to original for the TD-15 (and finding a recoil), or will you keep it with the creative paint and the TS rope plate and surround? BTW, that serial # on the rope plate is only a few thousand shy of the 1946 allocation. Since the war ended officially on 9/2/45 and consumer restrictions ended fairly quickly, that rope plate likely belonged to one of the first post-war motors sold. My guess is that was the attraction to whoever previously attempted to restored it.
      #25727
      clemg
        I will most likely restore it to original. I would like to find a ts-20 that needs a pull starter and restore it to original. I just restored a TN-27 that was my great grandparents. I’m getting pretty good at similar models.
        #146174
        sloppyjoe
          I have two TS-20 Johnsons. Serial # 486245 was purchased “Used” by my dad in 1945 when he was in high school. It’s all silver in color. Serial # 492447 I purchased on Craigslist in 2012 for $30. It also is all silver in color.
          #153361
          lloyd
            If you need the leather primer pump seals as you almost certainly will, just contact me for the seals and instructions. Lots more good info for that model at pochefamily.org/outboard.
            #153362
              I have a 1941-42 TD-15 Johnson that’s silver.
              clemg
                Thanks a bunch! I’ll keep you in mind!
