I think I know the answer to this, but does anyone know of a johnson serial number guide to identify HP/years?
Obviously you can use the ID plate on the transom bracket, but I run into a lot of transplant motors or ones where the ‘dog tag’ is gone (either the metal one, or…really?…the STICKER that is used on newer motors).
Im hesitant to even rely on orifice plugs in carbs due to how many folks like to try to turn smaller HP motors into bigger ones when they arent really meant for that with a simple carb swap.
Thanks gang.
