Home Forum Ask A Member Johnson serial number scraped off
Viewing 10 posts - 11 through 20 (of 35 total)
  • #185509
    The Boat House
      RICHARD A. WHITE
        I see both videos….tried the second and it works just fine, well first few seconds anyway..
        classicomctools@gmail.com
        #185513
        hag
          Thanks Tubs I found it on you tube . Not too complicated. Question do you think it needs two newer Omc coils or would one suffice? Solder the spark wires to the one coil? Don’t know the voltage of the old vs. new? Probably not enough. Did you experiment?
          #185514
          stanley
            US Member - 2 Years
            Plug wire end to plug wire end test assumes there are no breaks in either wire or bad connection wire to coil.
            #185518
            hag
              Stanley so when connecting primary coil to ohm meter (wire to points and copper ground wire) I have continuity. When connecting ohm meter to both spark plug terminals at the coil …nothing. So assuming secondary is bad.
              Also Tubs, which newer omc coil part# number did you use?
              #185523
                Both plugs on the same wire will fire the plug with the least resistance. You get the same results by grounding one of the apposed twins wires and jumping the two plugs together. It will run on one cylinder. The cylinder with the lowest compression or the smallest gap in the plug electrodes. It is very difficult to get them exactly the same.
                #185527
                hag
                  Yup that makes sense Gary thanks. Any recommendations on which coil to use?
                  #185540
                  The Boat House
                    The Boat House
                      The Boat House
