Home Forum Ask A Member Johnson TD-20
  • #172693
    jimw
      I have 2 Johnsons model TD-20 with cast fuel tanks.Was that common?
      #172698
      reivertom
        They are early production ones, that are still using the TS15 type tanks, probably from ’46 when they started production back after the war. They were essentially the same motor with a few changes such as recoil starters and paint color. Later on they changed them to the cheaper, easily dented thin wall tanks. I have a ’41 TS15, and the tank is dent free even though it obviously is well used.
        • This reply was modified 5 years ago by reivertom.
        #173338
        lloyd
          When you get around to running them, you will need new primer seals. Look at Adam1961 post for instructions on how to order them, or just call me at 231-929-7479.
