Johnson TD 20 point ajustment
Home Forum Ask A Member Johnson TD 20 point ajustment
This topic contains 3 replies, has 3 voices, and was last updated by Mumbles Mumbles 2 weeks, 5 days ago.
  • Avatar
    Mike M
    Topics: 5
    #178014
    Not sure how to adjust points in my Johnson TD 20 .. how do I know where the high side is to make final adjustment? Any help with pictures would be awesome. Thanks
    US Member - 1 Year
    Topics: 43
    #178022
    Just look. The shaft is round except for where the flat is ground. So anywhere on the round portion.
    Avatar
    Mike M
    Topics: 5
    #178113
    Ok guys I have removed and polished and degreased the points and re set gap .. I have strong spark in lower plug and just a very light spark in upper plug this is by using my plug tester tube.. what should I do next?
    Canada Member - 2 Years
    Topics: 420
    #178116
    Check the terminal inside the plug boot for corrosion and a good connection with the wires core. If all is well, I’d start suspecting a bad condenser.
You must be logged in to reply to this topic.
