Home Forum Ask A Member Johnson TN 27 Question
  • #166791
    johnny
      Can someone tell me how many splines there are on a Johnson TN 27 driveshaft where it slides into the bottom of the crankshaft?
      #166795
        I can’t say off the top of my hat but they are multi splined. If I look around tomorrow, I should have a shaft out in the shop somewhere and could do a count.
        TN-27-28-DS-Seal
        #166797
        crosbyman
          Canada Member - 2 Years
          maybe… 8
          #166941
          johnny
            I have two TN-27s that the splines in the crankshaft are rusty and are striped. I guess the only way to fix them is with replacement crankshafts that have good splines. That’s why I am asking how many splines they have. I know the TN-26 model only have 4 or 5 splines.
            #166974
              Perhaps there’s a good “farmers fix”, or “crafty machinist” fix
              for the crankshaft?
              If so, I wouldn’t mind hearing them.
              Then again, probably lots of TN-27 parts “out there”.
                The parts motor I have in the shop was a coarse splined TN-26. Sorry to keep you waiting.
                If you have a bad shaft with good splines, the end can be cut off and grafted to a good shaft with bad splines. I’ve done this fix on quite a few motors with good results. When it warms up a bit, the ’69 Merc 200 will be the next one getting this treatment done to it. Watch for it!
                DSC01036
                DSC01042
                And another one.
                DSC01040
                DSC01045
                #167130
                bobw
                  Mumbles – very nice machine work. Great fix.
                  #167138
                    Ahhh, it’s the crankshaft which is boogered. OK.
                    Here’s a JW which had the splines stripped in both the crank and on the shaft. To ‘fix’ it, I silver brazed a socket to the crank and cut and shaped the top of the driveshaft to fit. The three horse JW doesn’t develop a whole lot of torque so it should last for a while.
                    I picked up a four horse last year with a Macgyver fix for stripped splines in the crank so I’ll see if I can’t find some photos of it. The way it was done might be the easiest way for your TN.
                    Here’s the JW three horse.
                    DSC00054
                    DSC00061
                    DSC00066
                    DSC00001
                    DSC00002
                    #167438
                    lloyd
                      I can’t get to my shop to count the TN 27 splines, but I think it is 8 splines.
                      If you need new primer seals and instructions for your TN, as you probably will, just contact me directly at lautharr@sbcglobal.net or 231-929-7479. I tried to post an ad in the classified section, but it wouldn’t let me.
                      Good luck!
                      #167444
                      crosbyman
                        my picture above shows in plain view 3 splines + one on each side edge of the picture for a total of 5 PLUS
                        3 on the back side which we don’t see so ……
                        grand total must be 8
